It is currently Thu Jun 26, 2025 6:09 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Jun 01, 2006 7:12 am
Jim
I don't use vacuum yet, I'm just setting up to do my bridges with vacuum but from what I have been told your clean up routine sounds good.
You can use a damp rag, might be worth following with a hairdryer as Mario suggests, just for a few seconds.
The last one is tough to answer depends on glue strength, Mix, and if you preheat the components.RussellR38869.6989583333
PostPosted: Thu Jun 01, 2006 7:16 am
[QUOTE=Mario] Hesh, that's the one. The "Little Dipper"....
The trick to getting the Hot Pot to run a steady temp is to keep it at least 3/4 full of water. More is better....[/QUOTE]
Yes... I saw your post about this before. I tried it and I get the same variances but they just cycle over a longer period of time.
Maybe I got got a bad one.
PostPosted: Thu Jun 01, 2006 7:25 am
Mine is exactly the same way Brock, more water just means longer cycle times.
PostPosted: Thu Jun 01, 2006 7:52 am
Here's what I use. Proctor Silex. 13$ or so...
   On the model I have, I just need to keep the temperature control at the very minimum and it's at 140 in a few minutes.
I also noticed that the kind of water you use will make a difference. Just like in a vaporiser. If your water is salty, it will heat up more so that soft water. I have a well at home and the temperature will be a bit more erratic. With distilled water, it stays very constant.
   That's why they say to add a pinch of salt to a vaporiser if it's not producing enough steem.
PostPosted: Thu Jun 01, 2006 5:05 pm
I forgot to mention that Consolidated Plastics (here) has many different size bottles that will suit your needs.
I also should mention something else: I work in an antique repair shop, and I see lots of old hide glue joints that didn't hold up all that well. I'm certainly not poo-pooing the stuff; I really like it. But it does seem to get quite brittle and weak after even less than 100 years sometimes. I don't know if this is because it was of poor quality to begin with, or if the joint was poor to begin with, or what. Just an observation.
